front uprights
Hi i recently purchased some front up rights and the bolt that clamps the mushroom insert in is missing any one know what size it is ?
Cheers, DaveyB |
M12x40 originally, but you want ~25 mm extra for the wing stay mount.
Update: grade 8.8 is OK, as it's what it was on Sierra.
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. Last edited by alga : 15th September 2012 at 02:11 PM. |
Mushroom insert
Hi and thanks for the help, could you also tell me if the mushroom insert is actually clamped in that position being the only way it is held in place, sorry if this is a stupid question.
DaveyB |
You also need a secondary fixing to please mr iva. normally a hole drilled and tapped with a bolt or grub screw fitted through upright into mushroom.......once you have it positioned correctly! i.e offset towards the front!
Mushroom insert
Thanks for the help are there any specific photos of this any where you could point me. Thanks again
DaveyB |
