Old 18th February 2010, 03:14 PM
semtexsteve semtexsteve is offline
Default seat belt mounting plate nut size
hi guys anyone out there now what size nut to use on the seat belt mounts as i can only get metric and in the book it is 7/16ths ??????
Old 18th February 2010, 03:56 PM
It depends how your going to fix your seatbelts. 7/16th is industry standard. If you buy a belt with bolts on, they'll be 7/16th. If you buy a belt with clip on ends, then the eyebolts are going to be 7/16th aswell
You can buy seat belt stuff from these guys
https://www.europaspares.com/HARNESSES/NUTS_and_BOLTS/EYE_BOLTS__STRESS_PLATES__SEATBELT_NUTS_AND_BOLTS_ 2335.html
Old 18th February 2010, 05:18 PM
7/16ths unf !
Old 18th February 2010, 07:01 PM
SeriesLandy's Avatar
Originally Posted by flyerncle View Post
7/16ths unf !
Make sure you get UNF as I went into my local bolt shop and asked for 7/16 and got UNC didn't realise untill I got the top harness mounts from 3GE.
Old 18th February 2010, 07:34 PM
Hi Steve
Personally, I would use the 7/16" UNF fixings
You should not have any problem getting that size nut, they are still in quite common use.
My local steel stockist keeps them at a cost of less than 10p each
Would have sent you some up but have only got 2 left
Old 18th February 2010, 07:59 PM
Originally Posted by Bonzo View Post
Hi Steve
I know I just asked for 7/16 and got the unc. I'll get round to changing at some point just havn't been near the shop yet
Old 18th February 2010, 08:02 PM
Sorry Steve ..... I meant that message for semtexsteve
Old 18th February 2010, 09:41 PM
Event the completely metric Sierra uses 7/16" UNF for all the seatbelt mounts! I've put aside the bolts just in case and cut out some of the captive nuts of the rear seatbelt mounts to reuse on the roadster.
Old 18th February 2010, 10:57 PM
Tilly819 Tilly819 is offline
I used M10, as long as they are m8 or bigger your fine acording to iva book 7/16 is about 11mm for referance i made some adapters fancy steped washers to fill the oversize hole in the harnesses
tilly
