Old 29th September 2013, 09:49 PM
Default MX5 direct fit chassis
For a long time I've stayed away from producing a chassis dedicated to one engine and gearbox set up as the whole point of the Roadster is you put your choice of engine and gearbox where you want them. After seeing where people call it a day with their builds I have come to the point where I'm going to produce an MX5 based Roadster that is more of a bolt together kit rather than an assisted scratch build.
The outer chassis rails and suspension brackets will be the same as the standard book spec chassis so if you buy the new wishbones they will fit a chassis made from the book. I have reworked the tunnel to get the engine and gearbox further back and get the gear stick from under the dash a little, this should also help get the weight more in the middle. I'm playing with the standard hanging pedal box to try and suit servo and non servo brakes and also make it adjustable for reach so hopefully should suit every body.
I've named this the TMXR chassis (Talon MX5 Roadster) it will be a Talon only product so I won't be publishing the drawings or selling through a 3rd party as I've put a fair amount of time and money in to it and I'd like some of it back.
To go with this I'm also making mild and stainless four branch exhaust manifolds as the engine being further back now means the passenger foot well would get rather warm, I'll post some pics when I have this finalised.
Old 30th September 2013, 12:25 AM
That is really nice work Phil, I think you could be on a winner there.....good luck bud.
Old 30th September 2013, 11:03 AM
Looks cool Phil. The steering support is Sierra design though, the MX5 column mounts like this.
Old 30th September 2013, 12:06 PM
No thats the Saturn designed steering column frame which is not adjustable for either height or reach, the brackets which are not shown that are made for this mount allow the Mx5 column to do both.
Up here for thinking, down there for dancing.
Old 30th September 2013, 01:31 PM
Oh cool. So on top of this it would be those brackets and your diff box to finish?
Old 30th September 2013, 05:27 PM
The production diff cover for both the 1600 and 1800 diffs are done I'm waiting on the 2mm plates to be laser cut which should be with me next week. I also have a direct replacement cover for the Saturn design which has the mounting arms.
Old 30th September 2013, 07:57 PM
Nice engine mounts, that should make sliding the engine in a little easier ! What's the crack with these ones then Phil ? How do you couple those babies up to the engine ?
Old 30th September 2013, 08:16 PM
The engine mounting plates on the chassis are the same as the MX5 front sub frame, you use the standard engine mounts that come with the engine and it just drops in to place.
Old 30th September 2013, 08:34 PM
Looks good phil.
A kit where all the brackets ie handbrake , brake flexi mounts etc would be good as they are the bits that have been a pita to do
Old 30th September 2013, 08:57 PM
What measurement is the sump under the chassis Phil?
With my sump 40mm under the bottom of the chassis the cam cover is damn close to the bonnet of my AGM bodykit (scrapped some paint of it).
I like the concept of what you are doing Phil as I believe the MX5 version will become more popular.
