Old 20th December 2009, 04:32 PM
fabrun fabrun is offline
modified
Old 21st December 2009, 11:55 PM
The upright measures 154-155 mm along the kingpin axis. See http://fridge.pov.lt/~alga/DSC_9346.JPG . The mushroom insert sticks out by 8 mm extra. The kingpin axis has a caster angle and the kingpin inclination, you can measure them approximately on the drawing on the page 75 of the book.
Old 22nd December 2009, 03:23 AM
thanks a lot
Old 22nd December 2009, 08:04 AM
LeonN LeonN is offline
It is all looking good man. There is a plan of seirra hubs compleat with mesherments some ware. Quick surch has found it for me umpteen times.
The peddal box: need a hydrolic clutch for BMW bits. The BMW one can be fabricated into the book box quite easaley.
Old 22nd December 2009, 09:30 AM
thanks again
i 've found him
http://www.haynes.co.uk/forums/showt...ght=sierra+hub
can i re use the hydraulic clutch from the bmw with this pedal box?
Old 22nd December 2009, 12:23 PM
Yer you can. I made a bracket to hold the mastersilinder to the pedal box and drilled a hole a bit biger than the cilinder but smaller than the boot making for a nice tight fit. I'll try and find a pic.
Old 22nd December 2009, 12:31 PM
boath BMW brake and clutch. You can just see the bracket poking out. Pm me if you won't a better pic or some dimencions for your cad.
Old 23rd December 2009, 10:14 AM
chassis in video
http://www.youtube.com/watch?v=5LYcZ2m1nMU
Old 24th December 2009, 09:59 AM
bobbyh bobbyh is offline
any chance of a copy of the model? thanks
Old 24th December 2009, 10:11 AM
i share (with everyone)
just send me a pm with your email
the 3d format you want
precise only the chassis or all the part
i'll can give everything which inside the book
