Old 4th October 2012, 06:52 PM
Default stock clearance sale
I am about to lose 20% of my workshop space to make room for my laminating area this means my haphazard storage needs sorting before I fall over it in the process. So I'm offering every thing at reduced prices to get it out of my way before I start putting up the new stud work.
3x basic chassis flat packs up to RS14 with type9 tunnels in 1.6mm wall ERW basic plates included £175 each P&P via TNT £30
10 pairs of top front wishones all with very minor surface rust that will clean off with elbow grease and a scotch bright pad £30 a pair P&P via TNT £10 7 pairs left
3 sets of rear wishbones including the M20 adjusters all with very minor surface rust that will clean off £90 postage included uk mainland only
2 pairs of rear uprights set at 30' to suit both disk and drum brakes clean £85 a pair SOLD OUT
3 sets of rear wishbones 2x top and 2x bottom including the adjusters with yellow polybushes fitted,these have been cleaned up degreased sprayed with etch primer and given 2 coats of 2 pack gloss black. These are part of our new 'ready to fit range' £200 postage included uk mainland only
message me through here or email me.
Last edited by Talonmotorsport : 11th October 2012 at 09:45 AM. Reason: amendments
Old 5th October 2012, 05:26 PM
Oscar Oscar is offline
I'll take a pair of rear uprights!
Been thinking about getting them for a while now so this seems as good a time as any.
Any news on the other parts I ordered last week? (wishbone end tubes, diff hangers, rear tub bars)
Pm sending
Photos of the project so far:
Old 9th October 2012, 08:34 AM
I've found enough basic chassis plates to add to the chassis flat packs the price will still stand.
Old 10th October 2012, 01:44 PM
Awesome deal!
Old 11th October 2012, 09:15 AM
My parts arrived yesterday. Might make some progress today if I get time!
Cheers Talon.
Old 11th October 2012, 09:40 AM
When you come to weld the bush tubes to the wishbones the area that has been cleaned up is where the seam is you can see it from the inside, make sure you put the seam in the middle of the 25mm and 20mm tubing.
Old 22nd October 2012, 11:42 AM
I still have most of this left if it does'nt go I'll get it grit blasted and paint every thing gloss black.
Old 8th November 2012, 07:06 AM
All parts have now been painted to save them from the dreaded rust rash unless otherwise stated so I can offer the following parts
Top front wishones sprayed with etch primer with 2 coats of 2 pack gloss black £55 a pair postage included uk mainland only 3 PAIRS LEFT
1 set of rear wishbones including the M20 adjusters sprayed with etch primer with 2 coats of 2 pack gloss black fitted with poly bushes £200 postage included uk mainland only
1 set of full wishbones with polybushes fitted and rear uprights set at 30' etch primed given 2 coats of 2 pack gloss black postage included uk mainland only £325
