Old 23rd July 2016, 02:26 PM
RonnieH RonnieH is offline
Default headlight brackets
can anyone please tell me the length of the tube for the headlight brackets? and also how far along the chassis are they welded? many thanks. Ron.
Old 23rd July 2016, 09:27 PM
garyt garyt is offline
mine are positioned directly above the upper shock mount , the length really depends on what light units you are going to use .
as you have to allow for the iva light measurements , ( I ended up cutting mine down as I used 7" headlights), so basically mark the centerline of the chassis, half the overall width (across rear arches) , subtract the iva measurement and that gives you the outside edge of your headlight, then subtract half of your chosen light diameter and that will give you the measurement to the mounting hole.
If you need me to take any measurements I can do that tomorrow , just let me know
Gary
