Old 22nd July 2012, 01:53 AM
stuart stuart is offline
Default microsquirt map
hi can any body help ,i am after a map for 1.8 zetec black top. i am using the microsquirt ecu if any body has one or can tell me were i can get one would be much appriciated or any other help to get engine runing thanks
Old 22nd July 2012, 06:33 PM
as far as i know microsquirt and megasquirt2 use the same map files as microsquirt is basicly ms2 in small format
only problem is some of the hardware is diffrent and you can use diffrent doner parts.
it would be ideal if everyone used the same firmware had 1 type of engine all using the same ign and fuel system but sadly its just not as simple as that as the fact that ms2/microsquirt can be configured to run almost anything is what makes it so good.
your best option would be to ask in one of the proper megasquirt forums or locostbuilders saying exactly what you have in the way of hardware and what firmware you have.
or possibly where you microsquirt came from
