Old 17th May 2016, 07:39 PM
Josh's Avatar
Josh Josh is offline
Default Fibreglass repair
Hi all
I bought my rear arches 6 years ago, finally got round to fitting them (this project has been dragging a bit!)
There are some large cracks, where I assume air bubbles have propagated? There are also various other hairline cracks. Can anyone suggest how I should go about fixing these?
I also recently painted my first fibreglass panel - the scuttle. It wasn't until the primer went on that I noticed a small crack. I decided to press on with painting however because at this stage I'm not too bothered, I just want to car on the road! For future reference however, how should I go about fixing this?
Thanks!
Josh
Old 17th May 2016, 08:26 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Would that have been saturn nts or Gillham that you got them off
The rear arch I would just dremel the damage out down to the glass and filler and paint or buy another pair
The part with the stress cracks get yourself some matching gel coat
Lightly sand the area with some 400grit
Wipe the area with the wifes acetone for remOving her nail tips (I can give you a link to buy her more
Dremel a very groove to open out the cracks down to the glass then mix up some gel and carefully spread into the cracks leaving slightly proud
Cover with parcel tape (sticky side down) it's not a joke trust me it helps the gel harden up properly
Remove tape and flatten back getting finer in grit till you get to 1200grit (I go to 2000grit) then Polish and buff the area to bring back the shine
Or buy some more arches and panels off me lol
Hope that helps
Old 17th May 2016, 08:28 PM
vmax1974's Avatar
I think the ral number for that blue is 5005
Old 19th May 2016, 06:40 PM
Josh's Avatar
They were from Triton, aka Fabbyglass I believe.
Thanks for your suggestions, I will give it a go and see how I get on.
If all else fails, I may just buy a new pair from you...!
Josh
