Old 25th October 2009, 09:56 PM
LeonN LeonN is offline
Default ali seats
has anyone done them yet?
had a quick search but to no avail.
i have made a better net than the one in the book from card . at least a moor ergonomic net , but i can not make a decision on the thickness of aluminum to use?
are there any rules to adhere to? bare the head restraint and correctly positioned harness holes.
Old 26th October 2009, 12:22 PM
Try this link, these look really good.
http://www.streetperformance.com/m/c...brication.html
Old 26th October 2009, 12:39 PM
Thaye do look cool. Apear to be in ither .100 or .125 of an inch and grade 5052 ally. My boss thought 3mm and did not mention a hardness. Any other thoughts?
Old 26th October 2009, 04:42 PM
thwang thwang is offline
hi
leon
semi hard is ok i would ask chris about the thickness you might beable to go down to 2mm with 5000 series ally.
thwang
have you mocked one up i would mind seeing one if you have.
Old 26th October 2009, 04:48 PM
Have a cardbord one. Need to cross check all the meshermants and angles with trig.
Old 28th October 2009, 08:42 AM
Old 28th October 2009, 08:48 AM
Tatey's Avatar
Tatey Tatey is offline
I have to say im quite impressed. Can i ask how you are planning on joining the seat together if you decide to go down that route?
Old 28th October 2009, 08:55 AM
TIG. the seat can be folded from one peace 750x1500 and has 4 seams eatch side that i will TIG weld together.
Old 28th October 2009, 06:15 PM
You now have the start of a mould for a fibreglass seat Leon !
Old 28th October 2009, 07:01 PM
Go on? Is it just cover that in glassfiber and resin?
