Old 31st May 2014, 07:38 PM
davepro62 davepro62 is offline
Default how much 3mm steel plate
Hi guys
I am half way through my chassis build and was hoping that someone can advise how much 3mm steel plate i will require for my chassis plate.
Thanks in advance.
Old 31st May 2014, 10:05 PM
Unless you have access to either a hydraulic guillotine or a good quality plasma cutter save your self a lot of bother and just buy a chassis plate kit from Gillham online, life is just too short to spend that much time cutting it with an angle grinder. A little tip get 2-3 sheets of A4 paper cut all the chassis plates and arrange it on your sheet, it will make the cutting order easier to work out.
Old 1st June 2014, 09:16 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
i bought about a metre square then said to hell with that and got some laser cut much easier and far less hassle
Old 1st June 2014, 12:25 PM
I only got the oddly-shaped parts laser cut, the rear upright parts, pedals, etc. The square ones are not such a big deal to cut out. I bought 100x120 cm or thereabouts and have about a third or a half left.
But if you want, a kit of chassis plates will save you a lot of noisy, dirty work and save you from a lot of iron dust in the garage.
