Old 15th July 2010, 10:06 PM
David_17's Avatar
David_17 David_17 is offline
Default D1 D2 D3 & D4
The diagonal chassis tubes mentioned in the title are thinner box section than the other chassis tubes (as you will know).
Just wondering, do i line them up central with the 25mm box or flush with the outer edge of the chassis?
Also should i weld the uprights first before fitting them? They're only tacked at the moment, and i might have to grind the tacks back a bit to give enough room for the diagonals.
P.S. I've just updated my build blog if anyone's interested in having a look at a few pics.
http://davesroadster.blogspot.com/
*updated 7/6/11*
Old 16th July 2010, 07:20 AM
dogwood's Avatar
dogwood dogwood is offline
Flush with the outer edge.
And yes, I would fully weld the uprights before fitting them
David.
Old 16th July 2010, 07:34 AM
Hi David (17),
Just had a look at your build site diary....looking great, making some nice progress there ,
glad to see you got the genny sorted
I hope you don,t mind me saying, but from the angle of the photo it looks like you have placed part U7 in the wrong place, it needs to be 155mm from the center line of the chassis as in diagram 4.8 on page 38,
good luck with the rest of your build
Old 16th July 2010, 08:01 AM
dogwood's Avatar
Hi David (17),
Unless you got really teeny feet....
David.
Old 16th July 2010, 04:37 PM
David_17's Avatar
Think you might be right there. I'll have to check my measurements.
Thanks for the help.
*updated 7/6/11*
Old 16th July 2010, 09:05 PM
Enoch Enoch is offline
He's usually right Really irritating
Only joking Andy, you are a true legend. Annoying that you were right about my headlamp mounts though
Enoch
Old 16th July 2010, 09:17 PM
David_17's Avatar
Yep he was right
I'd done both uprights the same distance from the center, luckily it was only tacked.
Got that sorted, tacked the diagonals mentioned in the title and started fully welding the chassis then ran out of wire.
*updated 7/6/11*
Old 12th August 2010, 09:38 PM
gaz05 gaz05 is offline
Bugger. I've done the same thing. Good job I looked at this post today. I'll shift it tomorrow.
Total cost so far
Materials £3,150
Tools £855
Old 12th August 2010, 10:12 PM
Not the first & won,t be the last to do the same thing
glad the thread helped before you got too far on with your build .
Old 30th August 2010, 06:05 PM
D1 and D2. The book shows them as angled and it looks as if the left hand side one is rotated clockwise (from The rear) slightly. I would have expected it to be the other way to support the side panels. Can anyone clarify please?
Total cost so far
Materials £3,150
Tools £855
