Old 4th December 2010, 04:05 PM
David_17's Avatar
David_17 David_17 is offline
Default Brake pedal
Another probably obvious stupid question but what stops the brake pedal from flopping forwards?
if i rest it on the floor its too far foward, whats the reason for not having a support like the throttle and clutch?
Am i missing something? :S
*updated 7/6/11*
Old 4th December 2010, 04:22 PM
There's a limiting bolt that should be sticking out of the floor, supporting the brake pedal by a protrusion on its front face.
Old 4th December 2010, 04:23 PM
Tilly819 Tilly819 is offline
on the book pedals there is a tab that sticks out of the front of the pedal at the bottom.
put a bolt threw the floor (with a nut on either side) to line up with this tab then you have an adjustable stop
tilly
Old 4th December 2010, 04:24 PM
must learn to type faster
beet me to it
tilly
Old 4th December 2010, 04:38 PM
David_17's Avatar
Ah ha. Makes sense now cheers. I was going to put something underneath there as a stopper, never thought of making it adjustable.
Where would I be without you guys.
Another job for tomorrow.
*updated 7/6/11*
Old 4th December 2010, 05:56 PM
Old Git Old Git is offline
Mine's got the standard Sierra pedal box, and the brake switch (bayonet fit into the top of the pedal box) stops the pedal dropping right back.
