Old 16th March 2011, 10:28 PM
steve8274 steve8274 is offline
Default fuel fixings
is it acceptable to secure fuel pipe to copper brake using cable ties?
the brake pipes have been secured to chassis with appropriate brackets and rivets.
needs to pass iva
thanks
steve
Old 17th March 2011, 09:22 AM
Tilly819 Tilly819 is offline
No since the two pipes would be able to rub together
run the pipes threw there own seperate P clips
tilly
Old 17th March 2011, 09:32 AM
You can do, but the zip tie has to be fixed onto something solid (not an adhesive pad) and it must hold the fuel line tight without the chance of movement that could lead to wearing of the line.
Personally I used rubber lined P clips to hold my copper fuel lines.
Old 17th March 2011, 09:33 AM
little trick for questions like this. think would ford vauxhall etc do it like that? if its no then chances are it wont pass iva.
My Pictures
Old 17th March 2011, 11:49 AM
Are plastic P clips ok for fuel and brake lines or do they have to be metal?
Old 17th March 2011, 12:02 PM
Ashtonr Ashtonr is offline
They can be plastic
Old 17th March 2011, 08:23 PM
thanks guys for the replies.
i was kind of thinking it wouldnt be suitable but thought i would ask.
should have drilled holes etc for clips before i put some of my panels on. nevermind all part of the fun!!!
steve
Old 17th March 2011, 09:51 PM
Adequately supported is the explanation in the manual at 09d.
Well fixed and not fouling will please the man,if that is possible .
