Old 31st January 2010, 05:32 PM
davie h davie h is offline
Default its got to go
since the birth of my second boy and the fact that my garage has now been converted into another room. (it was that or move and we couldnt afford to move) i havent touched the car in almost a year and a half and i have nowhere to work on it i have decided to sell up. i have the following bits for sale if anyone is interested. delivery to be added on,or if anyone buys a lot i could meet halfway for the cost of fuel.
chassis complete made by myself with 3ge brackets £300 twinturbo
1.8 zetec pre aug 94 ,escort sump,flywheel and new water pump £70
zetec inlet flange £18
home made engine mounts for zetec with landrover bushes £25 teun
mk2 escort rack new never used only trial fitted £40 first dibs to tkpm
rack alloy brackets £15 tatey
3ge rack extensions new £18 tatey
new sierra track rod ends £10 tatey
3ge mushrooms £30 tatey
bottom ball joint (imp) £15 tatey
transit drag links £10 tatey
front wishbones £ 85 ryan
rear wishbones £85 ryan
rear uprights £50 twinturbo
wishbone bushes £70 handyandy
bike carbs £40
coli packs x2 £5 tatey
edis module and wiring plug with a crank sensor (wires cut) £15
edis/coil/crank sensor wiring uncut wire for crank sensor £10
pedal box complete pedals have the gripper tape on £45 teun
diff bracket weled £15 tatey
coloumn bush (sierra) £4
clarke engine stand £ 25 tatey
i also have a sierra registered in my name which is in bits wich includes the front uprights,front calipers,rear brakes,wiring loom, haynes manual, dials hand brake lever and a load of other bits save you the hassle of stripping one down. £100
if anyone is interested give me a shout as i have said if any one from down south wants a lot of bits i could meet somwhere over the border if needed. i have added picks of most things to my flickr account below.
Davie
Old 31st January 2010, 05:51 PM
thats a shame that you are having to give up.
on the plus side you will be able to start again one day once the kids are a bit older.
Old 31st January 2010, 05:52 PM
Tatey's Avatar
Tatey Tatey is offline
Im really sorry to hear you're selling up. I'll happily take the following off of your hands:
3ge mushrooms £30
Coil pack £5
You don't happen to have the steering column, cowl and key for the sierra do you?
Old 31st January 2010, 06:27 PM
tkpm tkpm is offline
Please could i have your,
Terry
Old 31st January 2010, 06:41 PM
teun teun is offline
Davie i would like to buy the pedalbox if you can sent it to Holland? Ofcourse i pay the shippingcost no problem.
cheers Teun
Old 31st January 2010, 06:44 PM
Ryan Ryan is offline
PM sent ref wishbones
Old 31st January 2010, 06:54 PM
Teun
if you pm me you address i will check the cost of postage and get back to you.
Davie
Old 31st January 2010, 07:09 PM
I will take the wishbones, Thanks.
Old 31st January 2010, 07:21 PM
Hi Davie i did pm my adres.
Thanks
Old 31st January 2010, 07:52 PM
with regard the wishbone bushes, is that a full set of the "poly bushes" including the crush tubes?
