Old 16th June 2011, 10:43 AM
whitstella whitstella is offline
Angry a great start for someone
hi after trying to get the build up and running i have failed and my wife is only 10 weeks from our first child. so if anyone is thinking about starting i have a few things to help you on your way.
CHASSIS (made by greaseymonkey)
All brackets welded in place chassis all welded.
REAR UPRIGHTS – drum type made by talon with adaptors to disc
NEW FRONT HUBS –reamed already
FULL SET OF WISHBONES – made by myself
3GE NYLON BUSHES + TUBES
CHASSIS PAINT
2 DIFF (1 push in, 1 bolt on)
2 SETS OF DRIVE SHAFTS
2 LITRE SILVER TOP ENGINE
1.8 CVH ENGINE
SIERRA WIRING LOOM
SIERRA DIALS
NEW FRONT CALIPERS
NEW REAR CALIPERS (disc type)
NEW DISC FRONT AND BACK
NEW PADS FOR REAR
2 ESCORT STEERING RACK
(1 new quick rack mk2 – 1 used rack mk1)
NEW POLO RADIATOR
NEW 2 MAXI BALL JOINTS
NEW 2 TRANSIT LINKS
NEW 2 TRACK ROD ENDS
STEERING RACK EXTENSION (talon)
2 OFFSET MUSHROOMS (aluminum)
SIERRA STEERING WHEEL (with key)
front frame/set of suspension brackets/25m of 25 x 25 box/12m 19 x 19 box section both 1.6 mm thick/3ge bush kit for pedals/various plates for chassis/ various bolts/2 used set of front uprights stripped/back plate for brakes and drums used and various othe part exhaust manifold.
OPEN TO OFFERS FOR JOB LOT NOT SPILTIING NEXT STEP EBAY THANKS FOR LOOKING.
steve
Old 17th June 2011, 06:32 AM
real sad to have to leave your build but there is always another chance latere on
if you do try and split it all up i would like to dibb's the rear calipers
Old 17th July 2011, 10:04 PM
poshguy poshguy is offline
What sort of money are you after for this lot
Old 3rd August 2011, 02:55 PM
samjc samjc is offline
Got the chassi still? ??
Old 7th August 2011, 09:38 AM
Richard Dryden Richard Dryden is offline
Would be interested in ]drum type rear uprights if you considered splitting
Richard
Richard
Just keep going we will get there in the end.
Old 7th August 2011, 10:29 AM
Grahamcuk Grahamcuk is offline
Default Hi
Hi How much for the lot and where are you based?
