Old 15th January 2016, 03:21 PM
SteveH SteveH is offline
Default rear shock problem
hi guys
Not sure if this has been covered before
But here goes
I'm just fitting my rear shocks and have come across a little problem
I'm using mx5 uprights and a set of talons wishbones
I can't get the upright to sit flush against the bottom of the shock
What would be my solution to this?
Regards
Old 15th January 2016, 04:46 PM
Thanks for the reply Phil
My first thought was to trim the upright a bit but I wanted to check first
Old 15th January 2016, 06:48 PM
Rosco Rosco is offline
Or just space it off with a spacer?
My Build Thread
Old 15th January 2016, 08:44 PM
That can't happen as the upright has to sit flush with the shock
Because with both adjusters in place there is no room for any spacers
Old 16th January 2016, 09:07 AM
RichardH RichardH is offline
the protech shock are designed differently at the bottom to give clearance, not sure about any other makes, just starting to look at this myself
Old 16th January 2016, 12:41 PM
The Gaz one does look badly designed.
Old 16th January 2016, 03:12 PM
thats the design i have been looking at
