Old 8th May 2018, 05:12 AM
RandyBMC RandyBMC is offline
Default OBP KC003 Pedal Box question
Hello all,
I just received an OBPKC003 pedal box, and there is no linkage for the throttle pedal. Has anyone used this set up? I am using an MX5 (1993) for a donor.
The last page of my build shows photos and poses the question. See here:
http://locostusa.com/forums/viewtopi...3774&start=195
Help! Thanks in advance.
Old 10th May 2018, 12:54 PM
MikeB MikeB is offline
I had to modify mine, wasn't happy just couldn't see how I could get it work as was
Untitled by mjb22001, on Flickr
I raised the pivot point and welded a bit on the bottom so the cable pulls from the bottom. not sure how it was designed originally, there may be better solutions but I couldn't make it work in my car as was
Old 13th May 2018, 04:32 PM
Thanks Mike - I worked out a solution. We'll see if it works! I posted photos of the start in my build thread (see my signature).
Old 14th May 2018, 04:26 PM
Buttoned up the pedal solution today. Take a look at my build log's last page. Input is welcome!
Old 15th May 2018, 12:14 PM
Looks great.
Annoying that for an expensive item there isn't a stock solution to attaching a throttle cable.
Old 15th May 2018, 02:05 PM
Thanks - totally agree! I requested help on it from Rallynuts and OBP, and just got the PDF of them drilling a hole in the end of the pedal. Wilwood has a complete bell crank bolt-on solution. As you said, for the money, I would've hoped even if I had to pay a little more I could've gotten a bolt-on solution.
Old 16th May 2018, 08:51 AM
I remember finding that pdf. looked at it and thought, that's no use to me! I would have paid a bit extra for a solution considering the faff I went through. I'm still not happy with mine as its no really adjustable. I have just enough pull to fully open the throttle
Old 17th May 2018, 12:33 AM
How is your pedal travel? Mine feels like it is too long. I remember reading something about that in Stot's build as well. I know Neil Cropper had made a smaller throttle body wheel, but I haven't heard if it worked. That'll be on my list after getting the car up and running...
