Old 10th June 2012, 12:28 PM
rpjg1975 rpjg1975 is offline
Default Marmite lights?
Found these on the bay of e...... can't decide if I like them or not? They are different but good different or bad different?
http://www.ebay.co.uk/itm/PAIR-OF-TR...item19c4205311
http://www.ebay.co.uk/itm/REAR-BRAKE...item1c1d180558
Russ
Old 10th June 2012, 12:34 PM
They're cheap and do everything and e approved! and dont look to bad i've fav'd them myself haha
Old 10th June 2012, 12:40 PM
Glad to be of help. have added a second link....think they look better!
Old 10th June 2012, 12:47 PM
For the money they look good, & you know I like a bargain
2 points to consider tho...
1) be aware when fitting them that the FOG light MUST be vertical to the road surface ( so , if fitting the clusters to the rear wings you,d need to possibly use a mounting plinth / angle thingymebob )
2) It states its "E11" marked, I,m not sure if that would be ok for IVA with regard the fog light as that needs a "F" marking ( its a fairly new requirement of the IVA thats easily missed )
Good find tho
Old 10th June 2012, 12:51 PM
Thanks andy, will have to investigate that a bit
