Old 6th August 2015, 09:37 AM
NeilW NeilW is offline
Today I might start to add fluids to box and diff as my new seal kit arrived for the gbox. I am sure everything is pretty much confirmed so they shouldn't have to come out anymore. Is this a silly idea?
Also what oils are people using in type 9's and diff? I have read mixed opinions about using high spec oils vs standard basic.
Total Spent so far - £xxxxx
Last Purchase - Engine mounts, steering wheel, slave cylinder.
Old 6th August 2015, 12:15 PM
EP 80/90 is the old spec and would have went in box and diff back in the day,filling the box now is a good idea as it is a pain when all panelled up.
It will run out of the tailshaft if not carefull.
Old 8th August 2015, 07:53 AM
I tried to tackle the gearbox seals yesterday and I am a bit concerned (as usual). The seal at the outer end where prop shaft inserts is a bugger to get out. Should I be ok to try and prise it out with a flat blade against the toothed shaft? Before I start I thought I'd ask how people have removed it. Google is full of info saying lever it against the shaft but some people report all kinds of issues.
Also, a noob question if I may.... Am I ok to cable tie the cv boots on the driveshafts? I got some metal straps included but there a pita to put on.
Old 8th August 2015, 03:20 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I had a quote from easi gears at thornaby and they were quoting 150quid all in to pull it apart clean and Inspect all the internals paint the case and put it back together with new seals maybe if you unsure its worth the coins
Old 10th August 2015, 09:24 AM
Lever it out gently and be carefull not to bend the splines,try the prop on afterwards.
Old 16th August 2015, 09:05 AM
Quick update, I am away now for a month so progress will be halted. I still plan for a Christmas finish (not sure which year though!).
Some progress was made last week..
Engine relocated slightly, needed to move 1" to the NS
Fuel tank and mushrooms - thanks to Kev
Front hubs reamed - thanks to Paul
Got some new 15" speedline corse alloys with Michelins
Eaton M45 received - this will be sold on later (surplus to requirements now I have another plan).
Now the fun part....
In the states Zetec performance parts are everywhere. So far I have purchased a rotrex c31-80 charger and kit, powerworks inlet and a Ford Racing Head (these are like rocky horse s**t). Awaiting delivery of an Omex ecu with a bit of luck (only $400).
The search continues but I am sure I am over my weight limit now - looks like additional baggage required!
Old 16th August 2015, 05:35 PM
vmax1974's Avatar
Can see you shipping an iso container home as your excess luggage
Old 17th August 2015, 02:15 PM
norton norton is offline
Is that M45 up for grabs then?
Old 17th August 2015, 10:18 PM
Yeah certainly is.
Old 17th August 2015, 10:22 PM
Can you send me any details along with a price?
