Old 3rd October 2010, 08:53 PM
steve8274 steve8274 is offline
Default cvh alternator wiring
hi all
come to put wires back on my 1.8 cvh alternator and cant find the paper what tells me where each wire goes.!
it has 3 nuts on it labelled W B+ and D+
anyone help?
thanks
steve
Old 3rd October 2010, 09:11 PM
Hi Steve,
I also have the CVH engine & alt, if your wiring still has the 3 nuts on the ends then they should also have the small "plates/guides" attached to them & so when they are offered upto the alt connections they can only fit 1 way, as the alt has small plastic channels where the wires connect to the threaded studs that the nuts attach to ,
well thats how mine works.
hope this helps.
Old 3rd October 2010, 09:21 PM
hi Andy
unfortunately i have decided to use an alternative loom. got 3 wires that are ready to connect to alternator but dont know which way to connect. i know 1 will be for the dash warning but which one? and what are others?
steve
Old 3rd October 2010, 09:29 PM
My apologies Steve, I thought you were using the original loom.
My car isn,t at home, if you don,t get the info you need sooner then I,ll check my wiring to the alt & post back on here tomorrow morning.
Maybe TT would know, I,m sure he,ll be along soon.
Old 14th October 2010, 12:09 AM
rpjg1975 rpjg1975 is offline
Not sure if it is of help but here is a pic of my 1.8 cvh alternator terminals while still fitted to the donor car...
Russ
