Old 1st February 2010, 10:16 AM
Tilly819 Tilly819 is offline
Default Iva 99dba????
hi all is 99.9 still 99 in the eyes of the IVA man?
I have managed to get my car down to 99.0 with the inroduction of a diferant back box and some sound deadning around the engine bay
but i dont fancy cutting it that close, iv ordered a bonnet scoop this morning to hopfully cut down the induction noise well at least muffle it abit.
also you now the exhaust wrap. if i use it then take it off 1 can u re use ( i think my dad fancys some)
and does it leave any marks on the manifold???
chears
tilly
(almost there)
Old 1st February 2010, 10:19 AM
Well done Tilly, you're nearly there.
Don't forget though that it's 3/4 rpm at max power rather than max rpm, may save you 1000rpm or so.
AndyH
Old 1st February 2010, 06:47 PM
i have only got to have mine done at 3750rpm as my max power comes in at 5000rpm. fingers crossed that its ok on the day
dont forget that at iva they do the test in an open area so its less likely that the sound will have objects like fences to reverberate off.
Old 1st February 2010, 07:04 PM
slimtater slimtater is offline
You can have my db killer as it didn't fit mine and I didn't need it on Sunday. Always worth having with you to pop in if it looks like being an issue.
Old 3rd February 2010, 10:22 PM
is it one you stuff up the can outlet slim?? if so i dont think it would fit because of the bend iv put on the end but i think i might have quietended it down almost enough now will have to test it again at the weekend
chears
tilly
Old 3rd February 2010, 10:32 PM
Yes it is a "stuff it up" one. No problem and good luck.
Old 3rd February 2010, 10:46 PM
chears slim, hope to have a bit of a pre iva check at the local garage emissions brakes etc this weekend then take it for a good shake down and get it weighed at the local airfield
tilly
ps hope it dosnt brake
