Old 3rd September 2013, 08:35 PM
StruveD's Avatar
StruveD StruveD is offline
Default Miata rear upright lower bolt
So i'm ready to bolt up suspension, and im wondering what you guys are using for the lower bolt on the rear upright. It looks like the upright is 14mm and the crush tubes are 12 mm. So what are you guys doing to take up those 2mm.
Old 3rd September 2013, 08:48 PM
You need 2 short lengths of 14x1mm cds tube and knock it in to place, it needs to be over length so you can trim it back and remove the leading and struck section that may get damaged.
Old 3rd September 2013, 09:08 PM
SteveMX5 SteveMX5 is offline
As above, I used stainless in the vain hope it might not seize in there like the standard setup does.
Old 4th September 2013, 04:30 AM
StruveD's Avatar
Welp not exactly something easy to come by over here. Found someone on ebay in the UK selling it. So I bought a chunk from him.
Old 4th September 2013, 06:54 AM
I used some 14 x 1 on my uprights to use a 12mm bolt, but there's no reason you cant drill/bore out the crush tubes to 14mm and use a 14mm bolt which may be a better option in the states if the tube is hard to come by or going to be expensive to get hold of.
Old 4th September 2013, 12:13 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
i used the 14mm x 1mm tube i got off ebay
instead of knocking in in i used some leftover m12 rod put a nut and washer each end and just tightened till it was all the way in
Old 4th September 2013, 12:24 PM
StruveD's Avatar
Cost about $20 US for 600mm of stainless steel. Most of which is shipping. So not cheap, but also worth it in the sense that i dont have to try and track some down.
