Old 7th January 2014, 12:53 PM
Wain Wain is offline
Default MX5 Hazard lights
I have a MK2 MX5 engine and loom. The head lights and side lights work but i cannot get the hazards to work.
All earth points are earthed. Fuse looks ok, but when hazard switch is pressed or indicator stalk is moved, there is nothing! not even a click from the flasher unit.
Any suggestions are appreciated.
Old 7th January 2014, 02:54 PM
Default hazard lights
Hi Wain,
Have you tried plugging in the instrument cluster. I know that with the NA version they won't work unless you plug this in.
Hope this helps..
Old 7th January 2014, 02:57 PM
Thank you for your reply. I do have the cluster plugged in, when the headlights are on the icon illuminates on the cluster, but the indicator icon does not illuminate when indicating.
Old 7th January 2014, 03:24 PM
there is an earth lead for the cluster which comes out of the loom near the connectors. is this part earthed?
Old 7th January 2014, 03:27 PM
All earth points that i have found are earthed, i am confident this point is one of them.
Old 7th January 2014, 06:34 PM
I think there are grounding points that need to be connected under the dash for the indicators to work. I can check when I get home.
Old 7th January 2014, 08:19 PM
No the indicators still work with the ones I was thinking about disconnected.
Old 7th January 2014, 09:47 PM
Default Hazard lights
Thank you for checking. I am confident that everything that needs to be connected is connected, although i have noticed that there is only one wire connecting to the hazard fuse at one side ( brown with a white stripe). I have been told that it is internally routed within the fuse box, so where does the other end of the fuse terminate?
Old 8th January 2014, 12:25 PM
I got my wiring diagrams here.
http://www.mellens.net/mazda/
Helped out more than the Haynes Manual did.
Old 8th January 2014, 12:52 PM
Default Hazard Lights
Thank you for the link, but i have already downloaded the wiring diagram for my loom and it looks the same. I will triple check the diagram again at weekend against the loom, but it looks like everything outlined in the diagram is connected.
One day it will be on the road......
