Old 8th July 2009, 10:11 AM
geeman's Avatar
geeman geeman is offline
Default Cp2 ???
Im probably missing somthing very obvious here, but which way up does plate cp2 go?? does the side thats 40mm go at the top or the side which is 80mm at the top?? it should be obvious, but i dont get it?
my build pics
Old 8th July 2009, 10:19 AM
CP2 are placed so the 40mm is at the bottom, its basically a stopping brace for the rear frame when welded to the main frame of the chassis.
Old 8th July 2009, 10:32 AM
geeman's Avatar
Thanks, will weld it on now.
my build pics
Old 10th July 2009, 09:13 AM
geeman's Avatar
one more thing , on cp3 and 4 you can see on the diagram on page 173, that rs15 is offset slightly from one side, but it doesnt give how many mm ofset it is, anyone know?? Again, im probably missing the obvious??
my build pics
Old 10th July 2009, 09:25 AM
its approx 3mm , basically allows the thickness of the steel plate of CP6 to butt upto it to create the straight box when it all gets welded together.
hope that helps
Old 10th July 2009, 09:57 AM
geeman's Avatar
ok, before i weld anything, can someone confirm for me if this is right, as im not sure it is. THe side of the nuts which is 45mm mm away from the edge is written on.
Thanks
my build pics
