Old 9th January 2012, 03:10 PM
Peter-C Peter-C is offline
Default Fog light angle for IVA
Hi,
I hope this has an obvoius answer. What did anyone use to get the rear fog light to be vertical. It seems a triangular spacer will do, but I can't find any.
Any ideas ? I'm having a thicker day than normal !
Peter
Old 9th January 2012, 06:04 PM
Why not set the lamp into the rear panel so that the base is in the inside(its usually wider than the lens)and space the top edge with a spacer to give the right distance so as the lamp is vertical.
Old 9th January 2012, 06:15 PM
shh120m's Avatar
shh120m shh120m is offline
or use a pice of plastic drainpipe cut at the correct angle to put between the back of the lamp and the rear panel.
Old 9th January 2012, 06:28 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Piece of drainpipe cut at I think its 12 degrees for the grp rear end
Old 9th January 2012, 07:35 PM
Thanks for your replies. My lights are rectangular and so the drainpipe solution won't look quite right I think. So tomorrow at work I'll have a practice on sinking them into the rear tub.
Peter
Old 9th January 2012, 07:52 PM
Peter,cut the right size hole in some card before you do the real thing and it it will give you some idea of what you need to get the angle correct on the inside for the spacer.
Any wedges/spacer used will be fitted inside the panel so as not to be seen.
Old 9th January 2012, 07:55 PM
Can't remember what tv show it was but i remember them making triangle wedges for this purpose out of Filler and Painting black to blend in.
Old 10th January 2012, 08:28 AM
You could always cut a wedge from a piece of wood for IVA, then chuck it in the bin after.
Old 10th January 2012, 12:20 PM
Originally Posted by Powler View Post
Hi,
Peter
Look at the photo at the bottom of this build diary.
http://tigeravonbuilddiary.blogspot.com/
Old 11th January 2012, 06:50 PM
a spacer can be made from bodyfiller and a make shift diy mould.
some people have even taken tape and set the lamp at the angle wanted and filled the void with body filler then sanded to get a good finish.
other ideas have been short angled bits of tube of some form or making steel or alloy bespoke mounts.
iirc the fog must be pointing directly backward or squarely to the rear in iva book
