Old 17th February 2010, 10:08 PM
les g les g is offline
Default pipe/tube beading tool diy
somebody on here was asking about a tube/pipe beading tool
the other day..
a guy(O2GF74) has posted his home made beading tool
very diy but the idea can be used for bigger/smaller pipes etc
its very simple and also quite clever really
a simple and effective solution
good man sharing it with everybody
hope its of interest to somebody
cheers les g
PS: its under the heading .....can you see what it is yet
Old 17th February 2010, 10:22 PM
Not a bad idea is that Les
I was thinking of turning up a male & female set of rollers ( Not unlike a set of tube cutters ) in the lathe.
Set them into a pair of sturdy fingers, add an adjustable clamping/pressure screw & Bob's your uncle
I had a look at some of the Pro ones .... Friggin hell, have you seen the price of em
Old 18th February 2010, 05:08 PM
hi Ronnie
yes thats a good idea as well.
i also thought that if you made one similar to Matey,s
with a good chunky bottom bit to hold in the vice
a fixed stop to hold the pipe against
and the top bit heavy enough to hit/tap/beat with a hammer.........
you could rotate the pipe one handed and and tap away with the hammer
it could be a nifty solution
if you get what i mean
cheers les g
Old 18th February 2010, 05:30 PM
Hey Les, that's not a bad idea mate
I suppose you could fabricate a hinged anvil & dolly to clamp in the vice + a little sping to stop it bouncing ..... Probably makes no sense but you have given me a cool idea & probably persactly what you are thinking
I feel another one of my dodgy " Windows Paint " sketches coming up
Old 18th February 2010, 05:53 PM
yes thats exactly what i mean
i dont do sketches unless they are on the back of an/oil
filter box lol deffo not on a computer
cheers les g
Old 18th February 2010, 06:04 PM
fabbyglass
Sand fill the tube to be bent and it won't crush....gentle heat will make it easier
Old 18th February 2010, 07:29 PM
Beading Mark .... Not bending I blame the Black stuff
Here's another of my dodgy sketches !!
Is that what you was thinking Les ?
The lower former could make use of an old woodruff key, inverted & tacked into place .
Or a profiled piece of hardened steel.
The upper former could be made with a small round file or ground out. A tad oversize to the lower former to allow for material thickness ( A couple of mm's should do the trick )
I really must learn to use the Autocad or Solid Edge software I have installed on this PC ....... I havn't got the faintest idea
Old 19th February 2010, 12:02 AM
thats the fellow Ronnie
i reckon thats almost marketable
perhaps you should put a patent on it.............
or make me one to test for when my wonky leg is better lol
cheers les g
