Old 2nd August 2010, 11:17 AM
Eternal Eternal is offline
Default steering column center?
Hi all.
Can anyone give me a hand and work out the center of the steering column in relation to the center line of the chassis? im using a granada column so the mounts are different also my chassis is a bit different so having a hard time trying to work out exactly where i should put the column. Also this will help me position the plate that the column goes into.
Skyline Roadster
Old 2nd August 2010, 01:50 PM
Surely you would want the steering column in the centre of the drivers side of the car.(middle of TR 9 section on drivers side)
Old 2nd August 2010, 05:47 PM
David_17's Avatar
David_17 David_17 is offline
yep, as above, the transmission tunnel is different both sides, so the center of the chassis wouldn't work.
The center measurement of the drivers footwell/steering mount can be worked out looking at cp16 (or cp17 I think) it is in the back of the book.
*updated 7/6/11*
Old 2nd August 2010, 05:58 PM
According to my cad model it is 290mm from the centerline of the chassis to the steering column centerline.
Old 2nd August 2010, 10:59 PM
Great thanks guys. Will have another look in the morning with fresh eyes, sure that will help.
Skyline Roadster
