Old 18th April 2012, 05:05 PM
Caber Caber is offline
Lightbulb Build a sports car for £250!
I built a Ron Champion Locost and was going to build another with a friend who ended up going to Germany to work. I did amass the majority of the major parts for the second one which I really must admit I am not going to build now. I therefore want to sell off the bits as a job lot to give someone else a head start.
What I have is a book chassis, a Capri back axle, a 1.6 Pinto with Type 9 gearbox, a propshaft needing a new hardy-spicer, a pair of sierra uprights and adapters, aset of Laser alloys needing refurbed and a whole lot of other bits and pieces.
All this is stuffed in the back of my lockup so I don't have photos but if you are interested you really need to come and take a look. You can also have a look at my locost which is very similar to what you will end up building from these bits!
I am in Edinburgh so really best for someone not too far away. This really is a good start for someone to do a relatively quick build, sourcing parts ad building the chassis took me the first year of a two year build working weekends and a couple of holidays.
I am looking for £249.99, I know that is a lot less than all the bits I have cost e but it really does need to move on and get itself built!
Caber
Old 18th April 2012, 05:38 PM
tkpm tkpm is offline
Most of your bits will be of use to someone here, except the Capri axle, as we use irs system. But you never know someone might be interested in it.
Terry
Old 18th April 2012, 08:35 PM
"Book chassis" also apparently stands for Locost chassis, not the Haynes Roadster one. So, not much use for us here, except with the Capri axle
Old 23rd April 2012, 08:28 AM
snapper snapper is offline
A mate converted a book chassis to DeDion using a Sierra IRS, it's not a big deal, just a bit wider than a Capri axle
Old 23rd April 2012, 10:04 AM
MarkB MarkB is offline
De dion option is ideal for the early Locost as you use the same pick up points for the trailing arms etc, just got to mount the diff and away you go. Lot less metal too so makes for less weight.
Less bushes less moving parts less hassle
Old 1st June 2012, 06:36 PM
Akd68 Akd68 is offline
Caber
I don't suppose there is much chance of this still being for sale? but if it is i would reall like to buy it from you.
Old 1st June 2012, 08:23 PM
I would suggest you send him a pm.
Old 1st June 2012, 09:04 PM
Yeah thanks, i have just sent him a pm.
Old 11th June 2012, 01:21 PM
Angry
Spent yesterday waiting for someone to come and look at this stuff and they did not show or call I am now considering parting this out. THere are a pair of Sierra hubs with recon clippers and new disks, adapters and top and bottom ball joints all new. 1600 pinto engine, gearbox type 9, props shaft needs new hardy spicer, laser cut bottom wishbone plates. Capri axel and rs2000 rear brake drums backplanes and seal kits, and a book chassis? Now open to any decent offers for parts.
Caber
Old 11th June 2012, 10:06 PM
shh120m's Avatar
shh120m shh120m is offline
I know the feeling, im getting well annoyed with dicks on ebay bidding, and either not turning up or not even answering calls. Its pretty shitty when a timewaster outbids a genuine buyer.
