Old 8th November 2018, 03:31 PM
DaveyB DaveyB is offline
Default Drive shaft hard to turn ?
So I managed to tighten up my drive shaft nut to the torque required. Now with no wheels or brakes fitted it is quite hard to turn the shaft by hand is that normal ?
There is also no oil in the diff.
DaveyB.
Old 9th November 2018, 10:07 AM
jps jps is offline
DaveyB.
I've seen this mentioned elsewhere and the answer was 'yes' it can be very tight. I've torqued mine up using an impact driver - but it's only rated to about 200nm I think - so I found mine only a bit stiff with the hub on the spline and not a problem at all with the wheels back on.
Old 9th November 2018, 09:22 PM
Sorry to ask a same question again.
But do Really appreciate the help, jps.
Thanks again,
DaveyB
