Old 7th June 2015, 11:29 AM
RichardH RichardH is offline
Default talon wishbones/mx5
hi i have a set of talons wishbones, anyone else using them have any pictures of them fitted, trying to see what i need to salvage from the donor before i attack it witha grinder.
Old 7th June 2015, 05:02 PM
You need the rear uprights, half shafts and brakes with hand brake cables (DO NOT CUT THESE !!!) If like most you can't get the outer lower wishbone bolt to move let alone out cut through it with a cutting disk, you can always drill the rest of the bolt out later. If the top mount of the upright is completely shot replace with a 90A shore polyurethane replacement with a stainless crush tube with a 12mm through hole (these will be in my online shop soon).
This is what the TMXR wishbones look like when assembled with the upright in place, the gap will take a standard 34mm coilover.
Old 8th June 2015, 12:01 PM
Numplumb Numplumb is offline
Sent you a PM
Old 9th June 2015, 06:32 PM
SteveH SteveH is offline
would these be the wishbones i would have to use on my chassis
thats book spec
but im using a mx5 as a donor
Old 9th June 2015, 07:36 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Yeah they would suit your chassis
Old 10th June 2015, 10:47 PM
thanks guys i can start to strip the donor now i need the diff out to order the housing from phil
Old 11th June 2015, 08:11 AM
Early cars are fitted with the smaller/shorter diff and the later cars are fitted with the larger/longer diff, the covers are not inter-changable between the two.
You might find this link helpful....
http://www.miata.net/garage/diffguide/index.html
Old 11th June 2015, 05:47 PM
Old 11th June 2015, 05:48 PM
Old 11th June 2015, 05:49 PM
