Old 10th October 2018, 08:02 PM
DaveyB DaveyB is offline
Default Drive shaft hub nuts.
Hi guys I was just wondering if any one could advise on when tightening these nuts should I add some loctite retainer . The nuts are of a nyloc type but just thought belt and braces approach.
Any thoughts would be greatly appreciated.
Thanks,
DaveyB.
Old 11th October 2018, 11:06 AM
jps jps is offline
Thanks,
DaveyB.
I haven't seen mention of using threadlock - but Haynes says they have to be torqued to 300ft/lb or thereabouts - so I think they're fairly tightly in place anyway...
I've just refitted my rear hubs and driveshafts - will be interested to hear how you a) get the right torque in the hub nuts and b) get the right torque inthe CV joint bolts. I can't stop the hubs turning to tighten them properly!
Old 11th October 2018, 07:31 PM
assuming they are Handed nuts, then torqued up is all you need.
It can only be done with the car on the ground and even then you may have to add weight to the haynes to stop the wheel spinning. may even need an improvised long leaver to counter hold.
Old 12th October 2018, 07:27 AM
I was wondering about putting a plate on the diff and wedging it against the gearbox tunnel with wood to stop it turning. what do you think ?
Davey b
Old 12th October 2018, 07:52 AM
jps jps is offline
Davey b
I'm just going to use a long bar between the wheel studs when the time comes to fully torque things up
Old 22nd October 2018, 07:38 AM
If your going to do that jps i'd advise putting two wheel nuts on each of the studs you are going to use to prevent damage to the threads
Old 24th October 2018, 08:21 AM
trying to get my head round the diff locking idea.... And will it increase/decrease the force at the diff... Too early in the morning to work it out.
Old 24th October 2018, 10:43 PM
I used a pretty long piece of 25x25 tube, leftover from the chassis construction.
I drilled 12mm holes across it.
I put one of the wheel studs in the hole.
The tube was long enough to touch the floor and being blocked by the stud and the centre part of the hub, it stopped the wheel from spinning while I tightened the nut with the torque wrench.
It worked fine, and I did not damage the stud's tread. However, protecting the tread as Arfon wisely says can't hurt of course.
I used this technique more than once, and actually I always kept this tube which is still lying with my tools
2013-11-21_18-39-14 by Sylvain ROIG, sur Flickr
Old 28th October 2018, 06:53 PM
Thanks for the advice I have some box lying around so will try using a long piece of box and try that method .
DaveyB.
