Old 18th June 2013, 09:08 AM
Default New Version of the IVA manual
New version out yesterday:
http://www.dft.gov.uk/vosa/repositor...n%20Manual.pdf
Only about 50 changes to it, and only a week before my IVA
Old 18th June 2013, 10:10 AM
rpjg1975 rpjg1975 is offline
Perfect timing eh?
Much that is an issue?
Old 18th June 2013, 10:14 AM
From what I can see the main thing is that the chassis number must be fully welded onto a chassis member now if on a separate plate and the rear fog light must turn its self off when you turn out the lights and not come on again until you specifically turn on the fog light OR you have a warning buzzer that sounds when you turn off the lights but leave the fog light switch active to remiond you to turn it off.
Old 18th June 2013, 11:15 AM
Yeah, they're the only two changes I spotted that could be an issue, the rest seems to be correcting typos and rewording things.
There's some debate over whether we need to do the fog thing or not over on the locost forum, but I spent last night re-wiring my dash to put a buzzer in just to be on the safe side...
Old 18th June 2013, 12:16 PM
...I spent last night re-wiring my dash to put a buzzer in just to be on the safe side...
Exactly my thoughts.
Old 19th June 2013, 12:04 AM
thailoz thailoz is offline
I have a 1 year old Honda and it dont do that lol
Old 19th June 2013, 07:52 AM
Probably turns it off with the lights though. I've had 30 year old Saabs that have done that.
But they also turn the main lights off with the ignition.
Old 19th June 2013, 09:44 AM
Hi Skov,
Can you put up a diagram of how you are planning to wire in the buzzer. I am planning to use the original mx5 fog light switch so this will not automatically turn off.
Old 19th June 2013, 10:22 AM
There are changes to mot test coming up shortly so is probably in line with those changes.
Old 19th June 2013, 01:10 PM
I can see why they've introduced the foglight thing into the IVA. Must be due to all the deaths caused by people leaving there foglights on when parked up! Or because someone working for the IVA has to justify their salary!!
I could do with details on that too John, guess it involves a relay and a piezo. I'm guessing?
