Hi guys,
I've been setting up my suspension for the past 2 nights and have hit a couple of problems. I bought my rear camber adjusters from 3ge and I've found that they are no good. With them fully wound in (and a half nut for iva) they are giving me 3deg positive camber when I want 1deg negative. I've thought about replacing the adjuster with a rose joint (like ashg has done) however I can only find one place and they only have 1 in stock. I'm guessing I would also need a bush to reduce it from 20mm to 12mm. Can you get these off the shelf as I don't have a lathe. The other problem I have is ride height. I loaded the car up with beer and have tried setting the rear height to 150mm but with lots of tension on the spring I got it too 140mm. On the front, with no preload I could only get the height down to about 110mm (is this ok as its been mentioned 100mm). Would I be better off taking up the slack on the front and not worrying about the slight difference in height? |
Do you have the book adjusters or the tube and sleeve quick adjusters? If you have the book spec wishbones one way round it would be to just cut the threaded boss down and weld the tube ends back up. Don't get too hung up on ride heights as different size wheel rims and tyre profiles will give different heights.
Website http://www.talonmotorfabrication.co.uk/ Direct email phil@talonmotorfabrication.co.uk talonmotorfabrication@gmail.com Mobile office hours 07514098334 |
That doesn't sound right - are the wishbones correct to book spec. My rear ones are standard wishbones, the adjuster is just a tube with a threaded stud welded to it and I have set it as per Spuds advice - http://www.haynes.co.uk/forums/showp...0&postcount=28
I've got a half nut on the outboard ends and have got 1/2deg of negative camber.
Gallery 2 http://www.facebook.com/album.php?ai...4&l=a9831a9319 Gallery 3 http://www.facebook.com/album.php?ai...4&l=3f0d42c523 Gallery 4 http://www.facebook.com/album.php?ai...4&l=efb083b7df Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5 cd3a Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=1&l =fe779b358c |
I think they are book spec, bought from 3ge as I wasn't that confident welding at the time, I've never actually measured them to check if they are correct.
With the adjuster it's the polybushed tube with a m20bolt welded on but there is about 20mm of collar on the bolt so I'm losing that adjustment. I'll have a go at chopping that down and re welding to see if I can get some neg camber |
There should be no collar as it should have been M20 studding so the thread should be right up the welds. Have you trimmed your top wishbones down yet, if not I'll make you a pair of camber adjusters this afternoon?
Yep, and with the fully threaded adjuster I can fit a full M20 nut as a lock nut.
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. |
is the lock nut even necessary as there is no way the adjustre can rotate once in the upright,.
Rob
Fail IVA possibly without,you know what they are like
Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
The reason for the locknut, is to prevent any small movement between threads , if left, wear would occur over time leading to a possible failure, think of a loose nut on a bolt there is a small amount of "backlash"
| Thread Tools | |
| Display Modes | |
