Old 18th January 2017, 01:56 PM
dean211277's Avatar
dean211277 dean211277 is offline
Default Seat mounting
I have my seats and want to weld in the mounting points. The drivers side has a runner fitted the passenger side will be fixed.
Would 3mm x 40mm steel be strong enough to mount them to?
They'll be bolted through from the underside with an oversize washer.
Old 18th January 2017, 04:13 PM
garyout garyout is offline
I have just welded in inch be inch angle 3 or 4 mm thick and spread the load under seat with big washer it is very solid
Gary
Old 19th January 2017, 06:27 PM
jps jps is offline
I've done roughly the same, 3x 50 strip that the runners are mounted to, floor is 3mm alu under that. Plenty strong enough I am sure.
Old 19th January 2017, 06:56 PM
Dave F's Avatar
Dave F Dave F is offline
I used 25mm box running and I welded in some rod conectors to screw it to
These
http://www.fhbrundle.co.uk/thumbs/th...connectors.jpg01/titled/channel-support-systems-threaded-rod-connectors.jpg
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
