Old 28th June 2014, 01:09 PM
Originally Posted by PorkChop View Post
Sylvain, what is the fit like on the underside of the rails? Could it be possible (I've just come in from work, so this might sound daft) that your issue lies with U4/5, or is it a tight fit to both the top and bottom rail?
Thanks for the input Snapper. Yes, it is a tight fit to both the top and bottom rail at U4/U5 level. It is this point which defines the vertical position of the GRP panel. Out of this point, the lower edge of the panel touches the bottom side of the chassis.
I made a sketch that illustrates my problem. Chassis is in black, GRP panel outline in red.
SidePanelGaps par Voucht71, sur Flickr
The only wrong thing on the sketch is the lower front part. On the sketch, it looks like the GRP lower edge does not touch the bottom rail after the floor stops. In reality, it does. It is quite loose, but it touches the bottom rail, certainly due to the "flexibility" of the GRP on such a length. I will try to slide a 3mm aluminium strip between BR1/BR2 and the lower edge of the GRP panel to see if it can pulls down the panel.
Again, identifying where my problem lies is not my first concern, because where ever it does, I'm not going to change the chassis, and I really want to use these GRP panels as I had them done with a personalized colour, I don't have the budget, material and facility to make aluminium panels and paint them. So I need to find a way to attach them to the chassis.
Thank you very much.
Old 28th June 2014, 09:43 PM
Hi Sylvain,
please don't think that I was belittling your build, i was only suggesting a form of communication with your vendor, I didn't even know it was equinox.
i must agree with you that Ben does seem to promote equinox passionately and i have often wondered if there was any form of business connection
As you know i follow your build regular as i like a lot of alterations that you have made to the better, i.e. peddle box and steering rack support
kindest regards
Old 28th June 2014, 09:49 PM
Absolutely no problem Arfon, what I said in my post from yesterday was absolutely not destined to you.
Thanks for the advice and the kind words
Old 28th June 2014, 11:38 PM
Ben_Copeland's Avatar
Hi Sylvain.
I wasn't belittling your project I'm sure it'll look awesome when you have finished and will be the highest of standard.
The only reason I suggested the chassis could be out is the side panels come from a mould and they have fitted so well on mine. I would of made the same suggestion whether it was equinox or gilham or anyone else's bodywork.
You mention 10mm gap that you have to raise the nosecone? Suggesting the panel is 10mm out at the front! This is a little more than error in the thickness of the fibreglass. Hence the suggestion that there could be an issue with the chassis. I don't know who made the chassis as I haven't read you build reports. So no need to get defensive.
I haven't mentioned equinox in quite some time and this is the first in a while. Except for Robos the other day who had posted about how good the bodywork is.
As I suggested you have a chat with Dave about this as he would be my first port of call before posting pictures and asking for help.
Good luck with you car, sure it will all turn out fine in the end.
Old 29th June 2014, 06:33 PM
There are a lot of contradictions in this answer Ben. I will not answer point by point, I already spent to much time on that (and you can't imagine how uneasy it is for me to answer to this kind of things and making myself clear in English which is not my mother tongue).
Just one thing : the nose cone is lying on the side panel top edges, which are, at that place, 4mm thick. So the gap is actually only 6mm, not 10mm. Which can be a fibreglass problem, but again, I never said so. If my chassis was out of 10mm at the front, I'd rather plant carrots than building a car. The measurements between the lower face of BR1/BR2 and the top face of TR1/TR2 is exactly 355mm, so there is no problem with my chassis here.
2014-06-29_09-49-12 par Voucht71, sur Flickr
2014-06-29_09-49-27 par Voucht71, sur Flickr
I checked again the measurements at the rear, and it is the same, everything is Ok on the chassis side. I have pictures of these measurements too if you want.
Now that I'm proven innocent, I want to make another statement: I measured the vertical dimension of the inside of the side panel, from top edge to bottom edge. The measurements of Equinox's side panels are spot on too, nothing to say about that. So, why these gaps if my chassis is spot on, and so are the side panels? I think it is because of the shape the panel is taking when it is forced under the 3mm floor. The panel get a slight inwards curve, and I guess that's what gives these gaps.
2014-06-29_15-45-10 par Voucht71, sur Flickr
So no one is to be blamed, and everyone is making a wonderful job: me, Equinox, you, the Pope and and the Queen of Denmark. And as Voltaire said: "All's for the best in the best of all possible worlds"
... nevertheless, I still have gaps to fill!
Originally Posted by MikeB View Post
Think your chassis must be out somewhere, I've had to cut the returns off the side panels for a length in my engine bay as it was out a couple of mm. If I was you I'd either ditch the side panels and make them in ali or cut the returns off where needed and glue the side panel on with some carefully placed counterskinks that would be much better than having the nose etc raised up.
Mike, I really seriously considered what you said : rising the nose cone, etc. doesn't look to be a good solution. I really tried to plan for every other possible solution, but didn't get anywhere. I really want the side panels to be removable, I know myself, I'll have to remove them in the future, even when the car is on the road. So gluing is out of the table. I could cut the rerun edges, and trim the top edge of the side panels flush with the top of the chassis, but it will oblige me to bolt them from the side, and I think it will look kind of ugly to have bolt on the side, even dome head ones, it will look like a WWII plane fuselage ;-)
So, unless someone sees another solution, I think that raising the nose cone of about 10mm is the only way to sort out my problem.
The lower edge of the nose, under the radiator, will be solid mounted on FF1
2014-06-29_18-02-42 par Voucht71, sur Flickr
The front ends of the side edges are lying on the top edges of the side panels. To fill the gap between TR1/TR2 and the nose cone side edges, I plan to use a 25x10mm rubber strip. With rivnuts in TR1/TR2, the bolts will cross this rubber strip.
2014-06-29_18-03-52 par Voucht71, sur Flickr
2014-06-29_15-31-51 par Voucht71, sur Flickr
2014-06-29_15-32-18 par Voucht71, sur Flickr
Will this be acceptable?
Old 29th June 2014, 06:34 PM
New post because more the 4 pictures
To fill the gap between the top edges of the side panels, and TR1/TR2, I plan to insert 25mm strips of GRP (leftovers from timing the side panels), so, unlike the rubber strip, this will be solid. As the gap increases from 0mm at the bulkhead level, to 6mm in the font, I can put one bolt just in front of the bulkhead, one in the middle with about 4-5mm on packing material, and one at the front, under back end of the nose cone, with 6mm of packing.
2014-06-29_16-05-34 par Voucht71, sur Flickr
This makes 1 bolt every 300mm. So I can run a 25mm GRP strip on the 40 first front cm, then on top of it, another strip on the 25-30 first front cm
Again, will this be acceptable?
Simulating all that with rubber strips, pieces of GRP and clamps, it give something, in my opinion, looking not too bad, and everything finally fits together. But the main question: will this be strong enough?
2014-06-29_15-32-45 par Voucht71, sur Flickr
2014-06-29_16-14-54 par Voucht71, sur Flickr
The lower return edges of the side panels are flush with the floor, and the front end begin very long and wide, it becomes flush with BR1/BR2 very close to the front end of the floor. I will have no problem to solidly attach these lower edges of the side panels to the chassis.
2014-06-29_17-59-44 par Voucht71, sur Flickr
I'd like to have your opinion about this before going further (drilling, etc.). So, again, every comment, idea, opinion about my plan is very welcome.
Thanks a lot.
Old 29th June 2014, 07:53 PM
You seem very defensive yourself when you really don't need to be and seemed to have taken a suggestion to hurt, even tho I wasn't the only one to mention it. I'm glad both the chassis and the bodywork are fine dimension size, I was just picking up on dimensions you mentioned.
I'm also glad you seem to be finding good solutions to your issue. Think that's all that needs to be said.
Good luck with the rest of your build and hope we see plenty more pictures!
Old 29th June 2014, 09:58 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
build looking good sylvian glad you found solutions to the issues
you saying about not being able to make yourself clear as english as not your first language made me smile a bit cause you then went on to use all the comma's and full stops in all the right places putting all the english lot to shame lol
enjoying keeping up with your build
Old 29th June 2014, 10:19 PM
I think your solution will work fine. The bodywork actually looks really good, world's ahead of the stuff I bought off another supplier !
