Old 21st August 2014, 01:42 AM
StruveD's Avatar
StruveD StruveD is offline
I did single piece in mild steel stitch welded. Its a bit more weight, but I really didn't like the idea of something tearing through the alum. floor and running me through.
1 year of neglecting my wife and children and all I got was this car... Totally worth it.
http://www.haynes.co.uk/forums/showthread.php?t=12943
Old 21st August 2014, 10:42 PM
Originally Posted by jps View Post
Good to hear the thoughts. I'm going to stick to my guns for now - and go with 1 piece floor - and a removable tunnel top (fitted with rivnuts).
However - I am aware I may come to regret this decision - so will work on the basis that I can easily drill a couple of holes and use the jigsaw to take out the 'centre' section of the 1 piece panel if I decide to do so in the future...
Consider making an access hole beneath the prop flange, and having the best of both worlds. Also, the bits of gravel that make it into the tunnel will have a way out :-)
Old 22nd August 2014, 08:23 AM
Turn the edge up on the panel at a suitable point in the tunnel area and this might stop some of the crud getting up there.
Old 1st May 2015, 04:58 PM
vince vince is offline
would 1.2mm galvanised sheet steel be suitable for the flooring , with regard to strength and weight ?
would it be useful for the firewall etc also ?
as there is enough being thrown away at work to do everything i need
to add to the info , its a BMW build car
BB
Its not how fast you go , its how late you brake
Old 2nd May 2015, 10:13 PM
Sounds about right, especially since it's free!
Old 4th May 2015, 10:40 AM
Just dont try and weld it in !!!!
You can always put bars across the floor to support the seats.
Old 10th May 2015, 05:18 PM
thanks guys
i was going to rivet the floor , as i have lots of rivets and an air riveter ,
thanks for the advice on the floor brace for the seat mounts, i have sourced some material for that as well , its some 100mmx25mm open box section , this will allow several fixing holes for the seat runners for fine adjustment if needed
BB
Old 11th May 2015, 12:33 PM
jps jps is offline
Originally Posted by vince View Post
thanks guys
BB
Not sure what 'open box section' is - but I have gone with 25mm x 3mm strips on which to mount the seat runners. Avoids putting any more height than is necessary into the seat base - plus means you don't need to put crush tubes in - which you would with box section.
