Old 24th January 2015, 08:45 PM
You don't have to have a steering lock for IVA but you do need 2 forms of security. Just fit a key/ keyless ignition and an immobliser. That's why the ignition barrel and steering lock was handy.
Old 24th January 2015, 09:19 PM
Rosco Rosco is offline
Originally Posted by rpjg1975 View Post
Looking good there, sure someone will come back with a bright idea about the harnesses......I may well be wrong but I was under the impression that the steering lock was one of the things required for iva?
Russ
Yeah you can use the steering lock as one of the two but then I would have to uses the sierra ignition switch, and I've got to use the bike ignition because of the immobiliser in the key, I'm hoping that will count as two but if not I will get a key fob too
Old 24th January 2015, 11:52 PM
rpjg1975 rpjg1975 is offline
Ah cool, that's good then
Old 30th January 2015, 07:48 PM
Got a bit done this week,
Cut the lock etc off and made a stainless tube, still need to secure it
Also made some top hat washers for the column bracket
Got my plates for the footwell back from my fabricators
Old 30th January 2015, 07:49 PM
I've had these cut out of 2mm and a strengthening fold along the bottom where the pedal box bolts in
Also got a couple of front seat rails bent up, these will have nuts welded underneath
And sit somewhere like this, pedal box is next weeks job so then I can work out my seat position
Picked up a cat today to, it's a 400 cel custom chrome one, there only down the road from me, could of got a 200 cell high flow but didn't want any problem getting through my iva
Old 31st January 2015, 07:07 PM
NeilW NeilW is offline
Great build so far mate, nice clean look. Good motivation for me to pull my finger out
Old 1st February 2015, 07:29 PM
Cheers, yeah get cracking!
Old 1st February 2015, 07:30 PM
Down my dads all day today, he's built a cnc router, works like a dream
Made a flange for my zx10 fuel pump today, this will be welded to a tube then to the bottom of the tank to make a swirl/ sump
Made a ply one first to check holes and oring grove
10mm Ali plate
Old 1st February 2015, 07:31 PM
Took 25mins to cut this out
Then made a wheel with the correct offset so I can check clearance when we make the exhaust manifold
One side is a 205 tyre the other is a 185 tyre
12mins for this I think, it flys through timber!
