Old 31st October 2014, 08:55 PM
garyt garyt is offline
[quote=Rosco;99095]Your build seems to be moving on well too! Cheers
thanks ,trying to get all the plumbing done for the supercharger and sort out the exhaust manifold / pipework, also started stripping down the wiring harness ( it was a bit parky out so dining room floor was commandeered) getting some more bits together to make another push forward,
seems to be lots of bits and not a lot of room
really looking forward to the electrics... mmmmm
Old 2nd November 2014, 06:07 PM
Rosco Rosco is offline
We had another good weekend, my dad help too so got a bit done
Started off welding up the shock towers, my weldings ok but my mate who's a pro is going to weld my chassis up
Old 2nd November 2014, 06:08 PM
Then tacked the roll bar on
Then the diff mounts
Then made some foot plates for the rear stays
Next all the suspension brackets, which took a bit of time to make sure they were as good as they could be, we tweaked the legs of the front frame out to close the gap between the brackets so no packing was needed
Then took it from my workshop into my garage ready to go for welding next week
Old 2nd November 2014, 06:09 PM
Old 2nd November 2014, 06:10 PM
That's that, got the workshop tied out so we could move again as it was getting a bit tight with the chassis in there,
Then just cut the tube up ready for the wishbones
Thanks for looking!
Old 2nd November 2014, 06:44 PM
Originally Posted by SeriesLandy View Post
You seem to be blazing along. You'll be finished by next summer at this rate.
If you haven't already, make the plate that the steering column goes through from 3mm steel not the book 1mm. It's a real pita to change it after it's been fully welded on.
Ok mate cheers, prob use 2mm then as I'm trying to keep it as light as possible, is 1mm to thin then?
Old 2nd November 2014, 07:00 PM
It will flex when you brake. I changed mine to 3 and it was hard changing it afterwards. It also isn't really think enough for the steering column bearing.
Plan on using a different one if your going for a sierra column.
guide
Search ebay for SLFL 25 Self Lube Bearing.
Lastly. Cut out plate where the handbrake cable goes through and weld it in vertical rather than on an angle, as it puts pressure of the handbrake cable and doesn't let it flow as easily. Lastly cut 2 slits into the plate so you can get the cable through the plate without taking the cable to bits.
I hope I don't sound too bossy but they are things I would have done the first time if I was doing the car again.
Old 2nd November 2014, 07:20 PM
guide
Ok mate cheers, no problems, grateful for the input, how wide do the slits want to be? And I will order a bearing in a min!
Thanks again
Old 2nd November 2014, 07:24 PM
If your going to use mx5 bits you will need a different bearing btw.
For the sierra shaft you will also need part of the original bearing. (It's all in the guide)
For the cables, about 2-3mm slits just enough to get the cable through.
