Old 24th July 2015, 11:04 PM
Originally Posted by norton View Post
Can anyone advise on what offset 13 wheels one would fit to our cars?
I'm looking at 13x7 front and 13x8 minilites but I can't find any definite offsets used for such a wheel.
I used the mx5 daisy alloys and painted them black. They are quite light wheels and basically a copy of minilites
Old 25th July 2015, 08:48 AM
norton norton is offline
Thanks for the info, I'm using mk2 1.6 brakes front and rear. 250ish mm diameter I believe.
Old 28th July 2015, 07:57 PM
Can you submit a car for an ova with an lsd that prohibits individual wheels brake tests?
Old 28th July 2015, 08:09 PM
Not sure if it helps but my car has a viscous lsd and it passed ok
Old 28th July 2015, 08:14 PM
Will that diff be damaged if spinning one rear wheel on a brake tester whilst the other is stationary?
I'm looking at the bargain Ashcroft lad but they say it's needs the accelerometer test otherwise it'll be damaged. I know that's fine with an mot test but wil Mr Iva accept that?
Old 31st July 2015, 09:28 PM
Chassis painted (badly) floor on and many parts cleaned via electrolysis and wire wheel.
Boxes of goodies!
I'm aiming to get the arms, uprights, calipers, discs and wheels on then finish the pedal box. I can then route the brake and fuel lines. Then it's engine and exhaust time. At least that's the order I'm aiming for.
Does anyone have a link to some 3 way brake/fuel pipe clips?
Old 31st July 2015, 10:13 PM
NeilW NeilW is offline
Link http://www.jetpress.com/Products.asp...eClips-Triple/
Total Spent so far - £xxxxx
Last Purchase - Engine mounts, steering wheel, slave cylinder.
Old 1st August 2015, 07:59 AM
Thank you for the link.
I managed to get some 13" Team Dynamics the same as CTW's for a bargain price too. Mine are in Anthracite, I'm rather chuffed with those!
Old 4th August 2015, 04:38 PM
Can anyone recommend an alternative to Toyo R888's that isn't a track tyre and will come in 185/60/13 and 205/60/13?
By this I mean is cheaper but not junk.
Old 4th August 2015, 06:25 PM
I went with Yoko A021-R from Polley motorsports. 185/70/13. The 185/60/13s were £75+vat and the /70/ were £50+vat so worth the compromise for me.
They dont have them on their website any more but the page is still there so the may still do them.
