Old 14th July 2017, 07:07 PM
norton norton is offline
Some more progress today. The wing brackets are more or less done. I will cover them in a clear heat shrink to dull the edges some more and offer some stone protection.
http://i.imgur.com/VgD9Uzl.jpg?1
Headlights having a trial fit and the grill is painted and bits behind painted black.
http://i.imgur.com/nMG6xeW.jpg?1
The dash panel has also been widened, shaped to fit and given a carbon vinyl wrap
http://i.imgur.com/kZl3WUS.jpg?1
I need to make some decisions about the column. I don't want switch gear or an ignition barrel on it but it seems likely that using the oem MX5 gear will make life a lot easier. One of the stalks will be redundant though as I'm not fitting wipers so that'll bug me.
Has anyone had any success with using a bare column? I understand Caterham use wheel mounted indicator buttons or something?
Old 14th July 2017, 08:03 PM
garyt garyt is offline
Blinkstop.co.uk
Does various modules for the button indicators and wireless transmission for removable steering wheels , one has 4 functions and one 8 functions this enables left or right and both together for hazards
Old 15th July 2017, 08:45 AM
Thanks Gary, I'll check them out!
I have these for sale if interested.
£40 posted.
£20 posted.
Old 15th July 2017, 08:33 PM
Woot! Just bagged an Acewell 7659 dash for a fraction of the new cost!
I also found the manufacturer of caterhams bonnet latches and have 4 of those on the way. A nice saving instead of buying from caterham.
Old 20th July 2017, 06:16 PM
Can anyone shed any light on what springs I should order with my shocks?
I'm going to use a 12" rear and 14" front. I understand I'll need 250lb rear and 350lb front but, what length spring do I need?
Old 25th July 2017, 12:41 PM
Can anyone guide me please on what number of dash switches I'll be needing? I'm not going with a screen on this build.
Old 25th July 2017, 09:35 PM
Are you using stalks on the column ?
On dash hazards, fog, lights
On stalks indicators , dip/main, horn
As bare minimum
Old 25th July 2017, 10:08 PM
No everything is to be dash mounted or two column mounted indicator buttons if possible.
Old 25th July 2017, 10:22 PM
Ok if all on the dash then all of the above and they need tell tales on them for indicators are you having a removable steering wheel ? If not you could make a plate to go imbetween the wheel and boss to carry the buttons and use blinkstop for the timing so that they cancel or if on the dad a three position switch on it's side centre being off and left n right with manual cancelling oh and remember all switches to conform to radii requirements unless in the exempt zone behind steering wheel
Old 26th July 2017, 08:50 AM
Thanks for the confirmation. The wheel is removable yes. I was thinking a bracket around the column originally but your idea is a neat one, the wiring may be a sod though.
So my list consists of the following. I've added a flash button on there for the rage moments.
1. Side lights/dip beam - switch type - off/on(1)/On(1+2)
2. Main beam - switch type - off/on
3. Main flash - switch type - off/on momentary
4. Rear fog - switch type - off/on
5. Hazards - switch type - off/on
6. Horn - switch type - switch type - off/on momentary
7. Engine start - switch type - off/on momentary
9. Indicators - switch type - on/off/on
Edited to add, I'm just gonna use a toggle switch for the indicators, much easier and cheaper.
