Old 2nd April 2016, 03:06 PM
SteveH1 SteveH1 is offline
Ok so i haven't updated this in a while.
But i have been busy as i said i had to upgrade the power supply to the shed to run the welder properly so i have since done this and also installed new lights to brighten the place up a bit.
So since i have most of the the chassis tacked together i decided to fully weld up as much as i can and my bandsaw had broken so i couldn't cut anymore steel anyway
Im currently about 95%or more welded after about 6 to 7 hours of welding
Untitled by stephen harborne, on Flickr
Old 2nd April 2016, 05:35 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Does the dog help out much in the man cave
looking good keep the photos coming
Old 2nd April 2016, 08:36 PM
Rosco Rosco is offline
Looking good, welds look mint! Just carefull with all that wood about!
My Build Thread
Old 2nd April 2016, 08:50 PM
Yea she loves leaving me toys and balls to fall over
Old 2nd April 2016, 08:53 PM
Cheers yea I'm well used to fire lookout I've set my fair share of cars on fire in work
And i always hang around for at leas 20 minutes after i stop welding
Old 2nd April 2016, 09:12 PM
Ive also got a radiator to make up the rad mounts its from a mk3 golf
So i wasn't really sure about the mounting so there was a nose cone second on eBay
and after a bit of a bidding war it was on its way across the sea i also won a dash blank
Old 2nd April 2016, 09:15 PM
So as you can see the rad was touching the nose cone so that needs to be adjusted glad i found out now
Thanks to Vmax for an excellent service and even better packaging
Thanks
Old 2nd April 2016, 10:35 PM
vmax1974's Avatar
Glad they got there safe hope you happy with them
Old 2nd April 2016, 11:24 PM
rpjg1975 rpjg1975 is offline
I was just thinking they looked like yours!!!!
Russ
Old 4th April 2016, 12:51 PM
Depending on engine fitted the rad will go in front of it above rack mounts,where the two chassis rails run from front frame.
