Old 9th January 2017, 08:03 PM
garyt garyt is offline
hi steve cant find the pics I took but this is the relevant text that I did for Richard;
Right measuring back from the front edge of FF4 , the front return edge is 109cm back, and the rear bottom corner of the scuttle is in line with the front edge of U5
gary
Old 9th January 2017, 08:06 PM
looking at your pic with the alternator its the plug and wiring that get close to the shaft, also had to relieve my plenum support a tadge for piece of mind
Old 9th January 2017, 08:42 PM
SteveH1 SteveH1 is offline
Cheers thanks for that
Its actually lower than it looks in the pic and the support isnt in place but should be ok
Thanks
Old 15th January 2017, 07:37 PM
Got a bit more fabricating done
Handbrake cable mounting
Untitled by stephen harborne, on Flickr
Brake pipe mountings
Old 15th January 2017, 07:38 PM
I started doing some metal turning classes before christmas and have been making some stuff for the car
Earth points
Headlamp supports
Steering column tube
Old 15th January 2017, 09:08 PM
chris_smith chris_smith is offline
That's great work Steve, and helpful to my build as I'm about to start in handbrake location thanks
Old 16th January 2017, 08:02 AM
Thanks
I did move it over and forward from the position in the saturn plans so i can use the cables without having to change the length of them
Also i think it was just in an awkward position in those plans aswell
Old 13th February 2017, 08:18 PM
Mking Mking is offline
Your build looks great. The pictures of the wishbones are a great help. I am scratching my head about those at the moment and the Saturn plans I have are confusing me quite a bit. I hope that it will all become clear once I start making the jig and piecing parts together.
Matt King
Total spent: £0
Achieving an ambition
Old 26th February 2017, 01:04 PM
Anybody know what the outside diameter of the protech front springs are
Thanks
Old 6th March 2017, 05:28 AM
They're 1.9" ID nominal. The front 350 lb/in ones are 68mm OD, the 250 lb/in ones are 65mm OD.
