Old 20th September 2018, 03:34 AM
RandyBMC RandyBMC is offline
I've been scrounging to get good copies of the Mazda diagrams, but I think I'm going to spend the time color coding them (the ones I have are all black and white). I also labelled everything as I took it out of the car, so hopefully that will help the process. I am intimidated though!
Old 15th October 2018, 07:56 PM
SteveH1 SteveH1 is offline
the wiring diagrams are black and white or the loom is all black and white
Old 15th October 2018, 08:11 PM
Untitled by stephen harborne, on Flickr
Finished the fabricating on the expansion tank bracket
Bracket for top hose
Cooling system nearly finished i just need a new thermostat and a few jubilee clips
Old 15th October 2018, 08:19 PM
I had to move the steering wheel a bit closer to the seat
And i made a supporting bracket for the steering shaft
And i tacked the steering shaft extension in place
Old 15th October 2018, 08:34 PM
More wiring
I got my rear lights they are for a defender
I got all clear ones
Mounted my maf using some turbo intercooler piping
Mounted my fan aswell
Old 16th October 2018, 08:30 PM
Chipping away at it
Are the lights 'E' marked?
Old 22nd October 2018, 07:40 AM
As well as E marked ensure that the fog light has an f or a b mark as well as mine failed the test on the first visit
Old 12th November 2018, 02:24 AM
The wiring loom is color of course, but the diagrams I have are black and white print. They have codes, but not easy to work with...
Old 28th December 2018, 08:49 PM
Been away from the build for a while
Next on the list was too hinge the bonnet at the front
So i made a steel frame for the front of the nose cone which i riveted in place the fibreglassed over to give strength
Old 28th December 2018, 08:57 PM
Bonnet now in place
Bonnet in place passenger side gap to scuttle panel
Drivers side gap
This will not do
