Old 28th December 2018, 10:01 PM
SteveH1 SteveH1 is offline
Along came a grinder
Untitled by stephen harborne, on Flickr
And the i cleaned up a bit
Old 28th December 2018, 10:03 PM
Originally Posted by RandyBMC View Post
I've been scrounging to get good copies of the Mazda diagrams, but I think I'm going to spend the time color coding them (the ones I have are all black and white). I also labelled everything as I took it out of the car, so hopefully that will help the process. I am intimidated though!
The codes on each wire are just the colour of the wire
once you get into it its not too bad
Old 30th December 2018, 10:13 AM
Don't think I have seen a flip front on a Haynes, Looks good.
Could the gap not be "Brought together" or pulled in with a fastening?
Old 30th December 2018, 10:15 AM
Being colour blind, a black and white diagram with codes is fine... But trying to suss out the real wires is a pain
I seem to recall 90's peugots amazingly printed the circuit reference on the wire!
Old 30th December 2018, 04:54 PM
I really love the front hinged bonnet, I bought a bonnet that was a second and the return at the edge was poor, so I cut the return off, countersunk holes right along the edge of the bonnet and riveted in an ally rerun then went over the rivet heads with filler sanded back and painted it. No it isn't perfect but it did allow the bonnet to be held closer to the correct shape as I mounted 4 vertical pins from the chassis which then pick up on the ally return.
Old 30th December 2018, 10:36 PM
It lives again
https://youtu.be/6oTIjozuTWQ
Im happy out considering since the last time it ran ive changed the timing belt and done a coil on plug conversion plus lots of other wire chopping
There is one coolant leak on the plates i made for the coolant reroute which i just sealed up and maybe i need to get some gaskets to do it properly
Old 30th December 2018, 10:55 PM
I also did some wiring and due to the fact i like my fingers i made this to split the conduit
Got the side and head lights working aswell
Old 30th December 2018, 11:01 PM
There would of been too much pressure on it and it wouldnt of been right in the end anyway
The nuclear option is what will make me the happiest
Old 30th December 2018, 11:03 PM
This bonnet was supposed to be a second but to be honest it should of went in the bin it has already been cut in 3 before this
Old 31st December 2018, 06:09 PM
Picture kind of reminds me of a cow for some reason..
