Old 7th August 2015, 10:43 AM
Numplumb Numplumb is offline
Default IVA requirement
Hi what is required for security by the IVA?
I have a MX5 build the donor parts were sourced from a 93 mk1 but I don't have any donor documents (so will be Q plate ) the ecu is none immobiliser type it did come with a Sigma alarm which I don't have the wiring instructions for I have worked it out to cut the starter motor when armed, so I have steering lock and cut out will that do?
Regards MIck.
Old 7th August 2015, 03:09 PM
Might ask for documentary evidence for alarm system.
Old 7th August 2015, 04:25 PM
Regards MIck.
All you need is a key as the first and the second level of protection is the steering lock. If you start installing alarms you need certificates from installers etc
Old 8th August 2015, 08:41 AM
What about if the donor vehicle came with a factory fit alarm?
I was planning to keep much of the original loom and electrics from my Saab as the alarm system makes the car unusable if you don't have the key and transponder?
