Old 2nd April 2016, 09:15 AM
snowy2 snowy2 is offline
I bought a Motorcycle indicator relay (for Honda LED relays.....) it powered two standard bulbs and two LED's for two years with out trouble. ( Fronts were LED rears were normal bulbs.)
Honda relay was only £5.00
Old 3rd May 2016, 08:35 AM
RichardH RichardH is offline
bolt on bits on ebay does a led flasher with adjuster on it, fit the flasher and turn on the indicators and turn the knob till you het the corrrect flash rate, great for mixing bulbs and leds
