Old 8th January 2016, 08:03 AM
Rosco Rosco is offline
one other think, dont assume your sheet of plywood or whatever you use for your build bench is square, check it corner to corner before you start as i nearly had a chassis 10mm out of square but my dad noticed!!
My Build Thread
Old 8th January 2016, 08:31 AM
SteveH1 SteveH1 is offline
My ply wood was the same so i just cut all the bottom chassis rails and squared them then bolted them down
Old 7th February 2016, 09:44 PM
dean211277's Avatar
Thanks for all the advice, keep it coming I really do need it!
For the build table my plan is to use some angle iron to make a frame for the ply wood table top, is this a good idea? Or should I stick to a wooden one?
Not much to report, I have been stripping the donor and selling bits as I go and building a box of stuff I'm keeping.
Tonight I have ordered a TMXR flat pack kit from Talon, bit premature but hay ho it might make me work quicker at getting that donor stripped.
Old 29th February 2016, 04:47 PM
dean211277's Avatar
Getting very close to getting the shell removed now, the spaghetti junction of a wiring loom is labelled up and removed from the engine bay.
Today my flat pack TMXR chassis kit arrived so need to get the donor sorted asap and start the proper building.
http://rs1123.pbsrc.com/albums/l556/...h=480&fit=clip
Old 1st March 2016, 10:02 AM
garyout garyout is offline
Hi Dean
Are you getting wishbones from Talon to? Well worth waiting for and look the biz if you don't want to make your own.
I have also ordered diff mount and nose mount so it can be mounted like a Sierra unit that's not arrived yet so can comment but I will let you know
Garf😀
Old 1st March 2016, 05:43 PM
dean211277's Avatar
Hi Gary,
Yes I think I will get the talons wishbones and the diff case.
I want to make as much myself as I can but I think buying the wishbones will be a hell of a lot easier, especially the fronts.
The diff case looks a work of art I don't think it would be something I could replicate!
I will keep my eye on your build thread
Old 29th April 2016, 05:08 PM
dean211277's Avatar
Between painting and wall papering (got to keep the her indoors happy!) I have managed to get the body removed it was a fairly straight forward.
It was one rusty car! The angry grinder was well used.
http://s1123.photobucket.com/user/de...=copy&sp=false
Old 29th April 2016, 07:07 PM
Dave F's Avatar
Dave F Dave F is offline
It's a good feeling when the body's off. I hope you undid the hub nuts and rear uprigh bottom bolts or the fun times are about to begin.
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 29th April 2016, 07:34 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
is that experience talking
Old 29th April 2016, 08:41 PM
Dave F's Avatar
Nope, it's research speaking, I found all the posts of people who have hard times and managed to geth both hub nuts and both bottom bolts out with not much effort, can't get the bloody shaft out the hubs though but the nuts are off.
God loves a trier
