Old 30th April 2016, 09:26 AM
dean211277's Avatar
Originally Posted by Dave F View Post
It's a good feeling when the body's off. I hope you undid the hub nuts and rear uprigh bottom bolts or the fun times are about to begin.
Yes lucky enough I too read plenty of build threads and read advice from other builders so I have slackened the nuts off using a 4ft bar!
Anything else I need to keep off the shell Before it goes?
I have cut the chassis number off and removed the chassis ID plate and cut out the bracket for the handbrake.
Old 30th April 2016, 09:32 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Have you kept the fuel sender from the top of the tank
Old 30th April 2016, 09:37 AM
dean211277's Avatar
Yes I have removed the sender unit and the other bit which I assume is a return?
Old 30th April 2016, 12:54 PM
RichardH RichardH is offline
fuel sender has flow and return, the other bit is a vent
Old 9th June 2016, 07:40 PM
dean211277's Avatar
The donor has been completely stripped down now have a big pile for the tip and another pile of bits to sell and help fund the build.
Build table has now been built and I have marked out all the bottom rails.
[IMG[/IMG]
[IMG][/IMG]
Only recently managed to check the chassis kit out, couple of bits missing nothing major so think I will cut them myself. In fact some may not be used or be different on the talon chassis compared to the book chassis.
[IMG][/IMG]
Old 9th June 2016, 08:11 PM
Dave F's Avatar
Dave F Dave F is offline
[IMG[/IMG]
[IMG][/IMG]
[IMG][/IMG]
What bits are missing as someone who has just about finished putting together the jigsaw, there are a few bits that are different, on another note, did the gearbox mount come with the flat pack as I never got one and I'd appreciate you sending me the dimentions if you could, anyone else who has them would also work
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 9th June 2016, 09:04 PM
thats the gearbox mount in the picture, bit box section two inch wide cut at angle on both ends with slot in the middle. bolt a landrover rubber mount and 50mm square box on top.
i will try measure mine tomorrow
Old 9th June 2016, 09:08 PM
Dave F's Avatar
Thanks for that. I assume it's easier to cut it and place it once the front mounts are in.
God loves a trier
Old 9th June 2016, 09:53 PM
dean211277's Avatar
I wondered what that bit was thanks guys.
If you want me to I will take some close up pictures of it and measure it too.
I'm missing all bits for the front frame, which obviously I do need. I have started marking out the bits on some box section I bought for welding practice. Much head scratching on FF2 and FF3 but think I have it right now!
Also missing are:
SB 3, 4, 5 & 6 I'm guessing these are as per the book
RS 15 again I'm guessing these are the same as in the book
SW 1, 2 & 3 which I assume are different from the book?
TT 6 & 8 not sure if these are used?
Cheers Dean
Old 9th June 2016, 10:00 PM
vmax1974's Avatar
Get hold of phil he will get them sent out to you
