Old 4th July 2017, 11:45 AM
rincewind23 rincewind23 is offline
Default 4 point harness lower mounts
Hi all,
I've bought some Titon 4-point harnesses - the top mounts are simple enough, 10mm I/D tube welded through a crossbar on the roll hoop, but I'm not sure how to connect the lower mounts - similar tube through the box steel of the chassis, or tabs (of thick steel) welded to the frame? I've searched the forums with no luck, and the SVA book is pretty vague (either that or I'm not reading it right).
Has anyone used 4-point harnesses before?
Cheers,
Kev.
Old 4th July 2017, 01:41 PM
garyt garyt is offline
Hi yes most folk use 4 point harness the mounts are shown in the book
These are shown as a flat plate with a threaded boss seam welded on the reverse, However my iva inspector said that they would have been better with a 90 deg return at each end to give better support, these are then welded onto the top of the frame flush with the cockpit side of the tube
Huh gary
Old 4th July 2017, 02:19 PM
I am such a div, when I went back to look at the book they were quite obvious!
When you say a 90 degree return at each end, do you mean something like this?
https://ibb.co/i3BPLF (for some reason when I put the link in as 'add image', it doesn't display)
Old 5th July 2017, 12:05 PM
Yes just like that
