Old 24th January 2017, 04:25 PM
jps jps is offline
Default GRP sides a bit tight (in places!)
I've been dry fitting my GRP sides and found that they vary between being just right, too loose and too tight.
This is probably partly because I have gone for a 3mm alu floor and there are some areas where I can dress a couple of welds and maybe get 1mm back to work with...
Just right I can deal with.
Too loose is not so bad either - thanks to seeing how Sylvain has dealt with similiar challenges here: http://forums.haynes.co.uk/showthread.php?t=13363
The 'too tight' bit has already led to me putting a small crack in the gelcoat - presumably from trying to flex it too far - so I am not going to force the panels in place.
Any tips for what options I have to make things fit? Can I sand out the inside (i.e. the non-gelcoat side) of the panel to introduce a bit more room?
Old 24th January 2017, 04:50 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
You will be able to samd some of the glass resin side where it is too tight everyone has this problem and i am looking into ways of adding a mm leaway but i havent had any ideas yet that havent meant i have to remake the moulds
Old 25th January 2017, 11:19 AM
Cropper Cropper is offline
I removed the bottom return (but left the radius) & fastened the side panels with heavy duty velcro, then just ran a small bead of silicon along the inside. I used a 5mm dome head bolt at the front & rear for extra security, the rear one isn't seen & the front one isn't noticeable as its low down by the bottom wishbone, also used black bolts on black side panels.
The velcro works well & it's takes a lot to reomove the side panels, i also used it to fasten down the top of my transmission tunnel, which makes for easy access if reqd.
Old 25th January 2017, 11:14 PM
vmax1974's Avatar
I will add the sides to my list of new moulds
Old 26th January 2017, 06:20 AM
Ben_Copeland's Avatar
As above. Reduce down the thickness of the lip if possible.
I managed to get mine on without having to take any off. They were tight in places but gentle pressure slowly working along got them to stretch enough.
Old 27th January 2017, 01:05 PM
Rosco Rosco is offline
on mine, (equinox) one side fit ok and the other side was to tight and wouldn't go on, i used a sanding flap wheel in an angle grinder and sanded the inside edges till they went on, i did have to take quite a bit out if i remember correctly
My Build Thread
Old 27th January 2017, 09:30 PM
jps jps is offline
Thanks everyone, my panels are Equinox also so good to know it's not just me!
Old 1st February 2017, 07:45 PM
Original saturn pannels.
3mm Chequer plate floor.
Cut the lower lip off.
Old 5th February 2017, 12:46 AM
jps jps is offline
How did you attach them to the chassis?
Old 5th February 2017, 05:21 PM
not finished but will use a length of angle to pull them in.
